Can't rev motor - FirebirdV6.com/CamaroV6.com Message Board
Can't rev motor
  • Can't rev motor
    This has been an issue since I got the car, but I just ignored it since it doesn't affect its drivability.
    It seems that if I try to rev my motor while in park or neutral it ends up sputtering without even reving at all. I don't really know where to start with this issue. While driving there is no hesitation and it drives great, so I am lost here. Any suggestions?
    Re: Can't rev motor
    What RPM does the tach start bouncing? 3500 ish?
      Re: Can't rev motor
      There's a limiter.
      TEAM C6V6
        Re: Can't rev motor
        If I rev it anything above idle it sputters. It's the weirdest thing, it runs fine when driving but won't rev at all if in N or P.
          Re: Can't rev motor
          Rev limiters are set at 4000 in P/N/R and 5950 in any froward gear. Has your car ever been tuned, someone may have changed them.
            Re: Can't rev motor
            No, it was bone stock when I bought it.
              Re: Can't rev motor
              Weird problem.. not too much of a problem but could be an indicator of a failing part. Has it always done this ever since you owned it? And did you buy it new or was it pre-owned?
              TEAM C6V6
