longer oil filter question.. - FirebirdV6.com/CamaroV6.com Message Board
  • longer oil filter question..
    what are the pros and cons?
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: longer oil filter question..
    Pros: more surface area
    less oil bypassing the filter
    cleaner oil
    Cons: ??
      I use M201...same as M101, just longer. No real Cons that I know of.
        a con may be it costs a little bit more money (im assuming)
          There isn't much difference in the price for the K & N filter. I think the stock size is a # 1001, the longer one used for a blazer is a # 2001.
          2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
            The supertech I get is the same price either way last time I checked. (it's a champion filter)
              I put the longer one on my car a couple of weeks ago because the shorter one was not available. It works fine. I use the Frams from Walmart. I know some people think they are no good, but my cars have gotten very high mileage using those filters.
                The con(s) are, if you break a motor mount the front sway bar is going to rip the oil filter off.
                  thats a con, using a fram filter
                    hahah
                    btw, it does cost more for a bigger filter the 1001 k&n which i buy usually is about 12 $, and the large 2001 is about 15$
                      i have always used k and n oil filters i went with the 2001 instead of the 1001 which i usually get same exact price @ 12.99 so not bad at all!
                      2001 Camaro 3.8 A4
                      1991 3000GT VR4
                        they are the same price? wow, you'd might as well get the bigger one i suppose.
