car wont start - FirebirdV6.com/CamaroV6.com Message Board
car wont start
  • car wont start
    got in my car to go somewhere this morning and the starter just kept trying to start but the engine wouldnt turn over. thought it was just the battery so i charged it, but still nothing. i have half a tank of gas. oil pressure gauge is reading very low but thats probably just because the engine isnt running. all inside electronics are working fine. the engine just wont turn over and start running. any ideas?
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
    Re: car wont start
    is the starting making a high piched sound?
      Re: car wont start
      no? just the usual sound of the starter
      1999 v6 Camaro M5
        Re: car wont start
        Does it sound like an electric motor is running when you try to turn it over?
          Re: car wont start
          Unplug your MAF sensor, see if it will start then. Pretty easy test.
            Re: car wont start
            Check and make sure you have fuel pressure at the injector rail. Also make sure your getting spark.
              Re: car wont start
              i did that and it worked perfectly. why?
              1999 v6 Camaro M5
                Re: car wont start
                MAF is dirty or going (gone) bad.
                  Re: car wont start
                  im confused, how would the MAF have anything to do with the engine not turning over?
                    Re: car wont start
                    dude thats a sweet test!
                    too bad my 3.4 don't have MAF
                      Re: car wont start
                      Glad it worked. Got some help here awhile ago having the same symptoms and that is what did it for me.
                      :) Just try to clean it and see if that works. Otherwise take it with you to Autozone to get a new one.. the core charge on them is retarded.
                        Re: car wont start
                        As far as I understand just unplugging the MAF will make the engine rely on the MAP sensor alone just ignoring the MAF tables. Car isn't going to run very fantastic at all, but at least it will start and hold an idle.
                        If you plug the MAF back in after she's running I bet you'll get a gurgle and a stop a short bit later after the engine starts trying to use it to adjust your fuel volume.
                        That's what I understand it as, but I'm not a tuner/sensor-guru. All I know is it works. ;)
                          Re: car wont start
                          I now dub you Sir Guru.
                            Re: car wont start
                            Unplugging the MAF makes the PCM go in SPEED DENSITY mode where it ignores the MAF not showing correct airflow.
                              Re: car wont start
                              Awesome, glad somebody could explain it clearly. :)
