Well I found a PCM and the wiring harness for a 3800 series II but it's for a 1996 F-body, and the engine that is in the car that I bought is a 1999 3800 series II will there be any problems with the PCM and engine wiring harness not fitting or it throwing out codes?
actually....... it will bolt up. They each have the 60* bell housing pattern. The best thing to do is try to get as many parts to 96(or suitable sub) as you can. Not sure if the bcm will be an issue, don't think so but then I don't have the holy book haynes in front of me either for wiring schematics. Speaking of, study them. Also, teh oil filter adaptor needs to be switched to an f-bod, otherwise the swaybar will prevent the oil filter from being installed.
2013 Ram 1500 Big Horn
94 comero 3.4
I have been looking at the Haynes manual and it seems that the tranny from the 3.4L and the 3800 are the same bolt pattern. Not sure what else is different from the tranny though they seem to be the same in the book.
