My speedometer all of a sudden stopped working. Every other gauge works except this one. When I start the car up, the needle moves about a half an inch up,,and doesn't move anymore. My governor still kicks in..so my car knows how fast I'm going, but doesn't want to tell me. What's the problem?
Speedometer stopped working
might be fuse... just a guess :( cuz remember blew one in my car and my speedo didnt work99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
Originally posted by L32Projekt:
You know if DTC 24 was set by this?
Another possibility is that something happened to my recalibrating unit. Would the speedo just stop working if something happened to the module? Or would the speedometer just read inaccurate again?94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
funny my speedometer "broke" too, but I can turn mine back on with a switch...funny how my odometer is "broken" too ;) if your odometer doesnt work....dont worry about your speedometer, think of it as a gift from god...I had to pay 120$ to get my speedometer broken [img]graemlins/banana.gif[/img]
05' CTS-V
00' Camaro - SOLD :(
can you shift out of first... i had this problem and my speedo went dead and i couldnt shift? you have an scu2000 or another recalibrator right? If you loose power to the scu2000 your speedo will go dead. this happened to me, i just had to find a better ground, they are very picky. i'd be willing to bet this is your problem.
So my speedometer, odometer, and tripometer are not functioning. What can the problem be?
DTC 24 indicates there's something wrong with the vehicle speed sensor (VSS) that's mounted to your transmission. Let's see, if DTC 24 is set, it means you may have to replace your ECM or VSS. Or you may have a grounded circuit. You may have a poor connection at terminal B12. Check the VSS, should be mounted at the rear left hand side of your transmission.Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
I still dont see it as a problem...unless something else doesnt work...if it shifts fine and your cruise works, your good to go....just let it fly ;)
05' CTS-V
