Odd engine hesitation, only when wheel is turned - FirebirdV6.com/CamaroV6.com Message Board
  • Odd engine hesitation, only when wheel is turned
    If I take a turn and give the car a bit of gas, there is a bit of hesitation..like a second or so then the car goes. Any idea why only when turning? Going straight is no issue whatsoever so I'm kind of wondering what it may be.
    I haven't had the throttle body cleaned and I have a few exhaust leaks that I should fix. Can that cause this?
    W68, K&N, Flowmaster, Walker Cat, 18 x 9.5 Chrome Y2k C5\'s w/ 275/35/18 Kumho 712\'s, Susp Tech 1.2 inch drop front, 1.7 inch drop rear, Hotchkis Adj PHR,Slotted/Cross Drilled Rotors<br />Hawk Pads<br />Pics: <a href=\"http://community.webshots.com/user/franjobc-date\" target=\"_blank\">http://community.webshots.com/user/franjobc-date</a>
    Re: Odd engine hesitation, only when wheel is turned
    if it was the throttle body or exhaust, im pretty sure turning wouldnt make a difference
      5spd/auto?
        auto...
        ps thanks for the quick replies.
          Also, it is the first time I've driven the car in like 2 years. I did always start it up on a week by week basis. I put about 80km's on it on Saturday. Basically used up all my old gas and put in high octane.
            Does it act like its going to stall?
              almost on the verge of stalling it. But I'd say more on the running side. If that makes sense. It sputters a bit then it goes.
              I do remember when I was driving it as my daily driver before I garaged it......One day, I tried pulling a quick U-turn, and the car actually turned off! Started up again no problem.
                You get a trac light at all when this happens? Or do you even have traction control?
                  no traction light, no SES lights, nothing.
                    IAC maybe?
                      Are you holding the steering against the stops when it does this?
                        Power steering pump goin bad holding the belt up? How's the serpentine belt look? Yeah I'm guessing.
                        TEAM C6V6
                          Now that you mention it, my belt may have a few cracks in it. It is for sure time to change it. I'll do try that. Thanks for everybody's help it's appreciated. I'll update the thread when it's fixed.
                            power steering fluid full?
                              i hope you have high compression or you just wasted a ton of money
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
