Is it anywhere near possible to switch out the steering wheel for an aftermarket one?
Another random question...
Re: Another random question...
http://www.modacar.com/products/Chev...Camaro/MODASTW
Seems like they have a bunch... maybe you don't need an adapter? The camaro is designed to be on the track, unlike all the rice grinders out there.
I installed a mid 80's Trans Am wheel into my 1993 Firebird. The teeth on the hub mesh with the column ok, but I had to cut the "collar" of the wheel down. When I first installed the wheel the collar of the wheel hit the steering column so the teeth would not mesh properly. Once I cut the wheel back a bit it fit just fine.
Originally posted by nascar24jd View PostDid you get the engine installed? How is it running?
I ate a bowl of fail this morning.
Quarter Million Mile Club
