I have 94 3.4 a4 and yesterday i went out and i was driving at about 45-50mph and the car stalled on me. So i pulled over and turned the car off. I tryed starting it again and it started like it normally does so i started driving away about 50 feet later it stalled again. I disconnected the battery to try and reset the ecu and then the car would sometimes not start at all or start and then stall a few seconds later. I am at a loss... i have a new walbro 255 fuel pump, new plugs, wires, coils, ignition control module, cam sensor, fuel filter, and fuel pressure regulater... okay before i did the fuel pump i changed the fuel filter but the day before i did the pump i ran out of gas. could the fuel filter be clogged? i have had the new pump for about a month with no problems. please help with any info thanks guys
Help Please!!!!!
Re: Help Please!!!!!
could be a bunch of things, like a dirty crank position censor, fuel pump, etc.
im betting on something wrong with the pump
get an OBD scanner and tell us the codes.. even though they probably wolnt be very useful
i think this is something ingnition related or fuel like the first fellow said. does it stall by "bogging out, putting, or something, or does it straight up die while driving?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
it just dies.. i checked the tps about a week ago with my scan tool it was reading the correct voltage. my friend said that when he put in his walbro that the gas ate threw the wiring could this be a possibility? also brought the car to my mechanic and he said that he put power to the pump and its not getting anything. any suggestion?
