accel problem - FirebirdV6.com/CamaroV6.com Message Board
accel problem
  • accel problem
    I have a 2002 v6, ive been having some problems with accelerating and am not sure where i should start in figuring out the problem. idle is fine, reving when not in gear is fine, while in gear and pressing the pedal i have power and pull up untill round 2.5-3000 rpm, and for some reason it kinda cuts out there almost like a redline, it just doesnt really pick up speed or i cant feel the torque. any suggestions on where i can begin? coils, or fuel injectors, electrical? i only have 60k on it so im pretty sure there is no engine damage or anythign like that.... i hope well thx hope this is clear enough
    Re: accel problem
    what mods? when and what was your last tune,
    and most important, what have you found by using the search button?
    my other truck has a 50 cal mounted on it
      Re: accel problem
      After checking the obvious things I'd start with fuel pressure when the engine is under load. My fuel pump went out at 49K. Yours could be providing enough fuel until you get to those RPM's when accelerating, because the engine is under load. After that, there isn't enough fuel to keep it going. Just a thought........
        Re: accel problem
        Check for a clogged catalytic converter.
          Re: accel problem
          x2 after running it for a lil while look under it at your cat, see if it's glowing red or even bulged.
          TEAM C6V6
            Re: accel problem
            pretty much stock but i have the magnaflow exhaust and whisper lid, havnt doen a tune in a while but i do my own oil changes etc. but thanks alot guys for the input ill look at my cat see if it glows or any irregularity to it, if not i guss ill bring it in to a dealership(damn their prices are expensive).
