Tried doing a search but looks like this question doesn't get alot of responses. Any suggestions on how to get that last bolt in the rear out? I'm going to go out tomorrow and try finding a really deep socket that will fit my 1/4 ratchet, but I thought I'd check and see if there's another secret to it?
Passenger side valve cover removal on a 98?
Re: Passenger side valve cover removal on a 98?
You kidding me? The engine lift bracket comes right out. 3 bolts iirc. You do need a ratcheting wrench to make the job alot easier. I removed mine once, and left it off for easy valve cover access. Well worth it.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Originally posted by Bird_Of_Prey View PostYou kidding me? The engine lift bracket comes right out. 3 bolts iirc. You do need a ratcheting wrench to make the job alot easier. I removed mine once, and left it off for easy valve cover access. Well worth it.sigpic
It's 2 15mm's. I had to go buy a set of ratcheting wrenches to get the right size.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
i hate that bolT!! i still havent gotten it off. its in such a wierd angle too. its a huge PITA. good luck dudeLast edited by HeadyFirebird'00; 04-23-2008, 05:17 PM.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
