A lot of products are sold for cooling fuel lines, insulation of fuel lines, ect. Why are cooler fuel temperatures desirable? I was always under the impression you want cold air warm gas for optimum mixing.
fuel
Re: fuel
never heard of cooling fuel... can you point me at a product your speaking of? Thermodynamically it makes no sense whatsoever... the air is what you want cold so it's denser, but cooling the fuel is not going to make the air cooler because it will already be in the cylinder chamber by the time the two mix.
I'd say you've ventured too far into the electric supercharger isle...
Perhaps a fire prevention measure, or to keep them from vaporizing from the high heat of some seriously modified engines?
Re: fuel
Originally posted by landj View Postor to keep them from vaporizing from the high heat of some seriously modified engines?Let's flip a coin. Heads I get tail, Tails I get head.
Re: fuel
Originally posted by zpwn06 View PostA lot of products are sold for cooling fuel lines, insulation of fuel lines, ect. Why are cooler fuel temperatures desirable? I was always under the impression you want cold air warm gas for optimum mixing.sigpic
Re: fuel
Originally posted by landj View Postnever heard of cooling fuel... can you point me at a product your speaking of? Thermodynamically it makes no sense whatsoever... the air is what you want cold so it's denser, but cooling the fuel is not going to make the air cooler because it will already be in the cylinder chamber by the time the two mix.
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...5&autoview=skusigpic
Re: fuel
These cool cans have been being made since the 60's. They are much nicer now then the older ones were.
I believe NASCAR has a rule that forbids teams from " artificially cooling fuel" As well. If you don't think they work, Go look at some NHRA Super Stock cars, They all use them.sigpic
Re: fuel
Still waiting on the proof... So far what I have is the premise that:
1) if it's on the internet and someone is willing to sell it it must increase HP and
2) if it's banned from professional motorsports it must increase HP
3) if it's been around since the 60's it must produce HP
Electric superchargers are sold on the internet and banned from Nascar, but I guarantee they will do piddly for you on the quarter mile. So what else you got? I'd settle for a dyno on a lightly modified 3800 or 3400 engine like what 99 percent of us have showing the before and after of a fuel cooler (without any other modifications).
And for the record, NASCAR engines have carburetors, allowing large amounts of fuel and air to mix well before the cylinder, thats just a wee tiny bit different than an electric fuel injection system that has its injectors pointed at the intake valves.
It sure is getting hard for me to talk with my foot up my mouth.
Re: fuel
I suggest you both quit your bickering and grow up a bit. Try things out and see how they work instead of going back in forth with the he-said she said BS. Any more crap and I will just delete all the useless posts in here. Do some homework and testing.
Re: fuel
Originally posted by landj View PostGee golly, I guess if it's on the internet, and somebody is selling it, it must create oodles and oodles of horsey power. Gee wiz, my mouf has sho got a foot in it now.
this has been around for almost 50 years, and most drag racers use them.
Re: fuel
Originally posted by landj View PostStill waiting on the proof... So far what I have is the premise that:
2. there are many things that are banned that increase horsepower.. think about drag racing, why do you think they dont use more nitro?
3. if it has been around since the 60's and a LOT of drag racers use them, i think it works
do you realize how hot intake manifolds get? by the time the air is getting into the engine it is already hotter than the air around it, and cooler fuel will help cool the air, yeah i realize this is happening at a very fast rate, and it might not make a huge difference, but EVERYTHING helps, drag racers arent willing to add a 5 pound fuel cooler to their car if it is NOT going to benefit them.
i dont know a ton about them, or the reasons behind them, and im not going to look it up, you are under the impression that they are useless, and it is some gimmick like the "tornado" so why dont you do some research like previously mentioned?
also guess what, when fuel is cooled down it compresses, which means you can fit more fuel into the engine, more fuel equals more air which equals more power.
im betting you will get false readings on a computer controlled car due to the fluctuations in the timing, etc
Re: fuel
Originally posted by cam98aro View Postalso guess what, when fuel is cooled down it compresses, which means you can fit more fuel into the engine, more fuel equals more air which equals more power.
I'm interested in this vapor lock deal. Fuel only burns as a vapor...its almost impossible to burn liquid gasoline. So why is vapor bad? Another gas volume/compression issue?
Re: fuel
I'm interested in this vapor lock deal. Fuel only burns as a vapor...its almost impossible to burn liquid gasoline. So why is vapor bad? Another gas volume/compression issue?sigpic
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
