MSD coil packs any good? - FirebirdV6.com/CamaroV6.com Message Board
  • MSD coil packs any good?
    My ses light came on and its a multiple engine misfire. This has happened to me many times and last time I just replaced the plugs and wires. This time I am going to replace the coils and module. I saw the MSD ignition coils here is the link. Has anyone used these are they any good?
    http://www.partsamerica.com/ProductD...pe=190&PTSet=A
    Please feel free to give me any advice or suggestions. Later
    Re: Multiple engine misfire new coils
    i just did my coils on sat i went to the how to section it helped alot
      Stock is more than enough.
        does it do when you start the car at an idle and before the engine heats up? if not replace your o2 sensors, they will make it miss if they are bad
          Is it the Random Misfire code?
          My dad's car had those coils on them...definetly seemed to give it more "umph" if you will.... Stock coils are only 40,000 volts, where as those are 60,000.....
          Y87 Package
          MANUAL CONVERTED, Pro 5.0 Shifter
          Pacesetters, Magnaflow Cat, Cutout, Flowmaster
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          Team Black...TEAM EMO
          Come on kids! Get a Calendar!
            Yes it is a random misfire. I was thinking of buying the MSD ones just because they may be better, but I use my Camaro as a daily driver so I was rethinking of going with the stock ones intstead.
              The MSD's would be fine for a daily driver. Good, solid improvement over stock, but nothing that's going to kill gas mileage or streetability. you'll actually more than likely gain mileage because the additional spark power will more throughly burn the gas, so you'll get more out a tank. Nothing crazy good though. I'd go with them though. My bird is my daily driver, and I've even got a DIS-4 on it.
              As for your code, the coils might not be it. We replaced plugs, wires, coils, all that and it never went away. But what alot of guys overlook is the stator in the harmonic dampner. It's used to check misfires. we replaced my harmonic dampner, and BOOM. Code never came back. Turns out the stator was bent just barely, which kept making the PCM think there was a random misfire. You might want to look into the before you drop $180 on new coils.
              Y87 Package
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
                Re: MSD coil packs any good?
                $54.99 per coil!? Ewww...save money and get a trio from www.3800performance.com. $149.99.
                I got them on my car and a tune up is due at 275K...I didn't necessarily feel any difference, but they are pretty though.
                  Lol...pretty coillll....touchy touchyyyy
                  Y87 Package
                  MOGOB APPROVED!
                  BONE APPROVED!
                  VANBIBBER APPROVED!
                  KRISTEN APPROVED!
                  Vice Prez.
                    i got them because my stock ones kept shorting out, put msd on 30k ago havent had any trouble since. dont get accel though.
                    96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
                      anyone order from 3800 performance, how reliable are they?
                        I've ordered from them a few times and never had any problems. I don't know about the MSD coils though. Mine only lasted about 70,000 miles before they went bad.
                        2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
                          check out summit racing...thats where I bought mine from...think I only paid a little over 100?...
                            70k??? you dont think that is good service lfe fo an electical part?I love mine
                            my other truck has a 50 cal mounted on it
                            • Andy H
                              Transmission removal help!!
                              by Andy H
                            • 2.8 Bird
                              Abs inop
                              by 2.8 Bird
                            • fishin
                              by fishin
