Fuel pump replacement/problem - FirebirdV6.com/CamaroV6.com Message Board
  • Fuel pump replacement/problem
    I was wondering what all is involved in replacing the fuel pump in my 90 firebird? Does any of the exhaust have to be moved/removed? or do i just drop the gas tank? I cant hear my pump cycle when i turn the key to the on position, and sometimes to get it to start I have to turn the key to the on position, then turn it off...wait a couple seconds, then turn it to the on position then start it. I ran a fuel pressure check and sometimes when the key is turned to the on position it will pressurize to the right psi, then if you turn the key off and release the fuel pressure from the gauge, then turn it on it stays at 0psi until you turn it off then on again
    1990 Firebird 3.1 T-Tops<br />Flowmaster exhaust<br />Kenwood MP 825 Deck<br />4\" Rockfords w/ tweet in dash plate<br />3 Way 6x9 Rockords in rear sails<br />1970 Camaro 350
