damn blinkers please help... - FirebirdV6.com/CamaroV6.com Message Board
  • damn blinkers please help...
    okay guys i have been throgh 3 sets of front blinkers on my 2001 camaro in the past few years by blinkers i mean the housings.. they fog up and blow the bulbs really bad and the actual housing melts and busts and gets deformed i see this alot on f bodys is there a fix for it?
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
    Re: damn blinkers please help...
    Sounds like your using the wrong bulbs.
      i am using what it calls for i used to use the NA version (amber) then i switched to silverstars.
      2001 Camaro 3.8 A4
      1991 3000GT VR4
        Stop using the Silverstars and just use the standard GE bulb.
          Silverstars have worked fine for me. Check the current and voltage at the sockets, you may be getting too much.
          1996 Chevrolet Camaro
          1995 Buick Park Avenue Ultra
          --Appearance Moderator--
            they do it too an i have black blinker housings so anything other than silverstars look like ****
            2001 Camaro 3.8 A4
            1991 3000GT VR4
              Are the housings supposed top be black?? or silver/chrome?
                dont buy cheap enclosures?
                or maybe seal them up with some silicon?
                  i was thinking about putting small holes in the top and bottom of the housing so it could drain and air would rush in and out of it to help keep it cooler but i think i will try the silicone first
                  2001 Camaro 3.8 A4
                  1991 3000GT VR4
                    probably the blinker fluid.
                    Have you changed your filter recently?
                      ah blinker fluid i forgot about that! anywho i switched to led bulbs that should help out alot
                      2001 Camaro 3.8 A4
                      1991 3000GT VR4
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
