oil leak? - FirebirdV6.com/CamaroV6.com Message Board
oil leak?
  • oil leak?
    i have a moderately bad oil leak and i cant seem to find where it's coming from. At first i thought it was coming from the oil pan but it's not. I looked under the car and it is coming from somewhere around, or above the oil filter. It's not coming from the oil filter itself. What is around the oil filter that could leak?
    Re: oil leak?
    Oil pressure sending unit, they are known to leak after time.
      Re: oil leak?
      yep, mine leaked like a sive, when running
      my other truck has a 50 cal mounted on it
        Re: oil leak?
        30 bucks at napa
        Originally posted by kala
        I'll have buttsecks with Richard Simmons!
        TEAM BLACK!!!
        parting her out
          Re: oil leak?
          yeah thats what it was just tightened it. thanks
            Re: oil leak?
            just about the easies thing to fix!
            WAWA-A-HOLIC
              Re: oil leak?
              yeah i was freaking out lol. i was like " i dont want to pull the motor mounts and crap to replace the oil pan gasket"
                Re: oil leak?
                don't need to pull the mounts to do the op gasket lol i should know
                WAWA-A-HOLIC
                  Re: oil leak?
                  Good deal... I had an oil leak about two years ago, but it was on the back side of the engine...not exactly the brighest of forecast, turned out to be the rear main seal...man was that a B****.
                  Y87 Package
                  MANUAL CONVERTED, Pro 5.0 Shifter
                  Pacesetters, Magnaflow Cat, Cutout, Flowmaster
                  MOGOB APPROVED!
                  BONE APPROVED!
                  VANBIBBER APPROVED!
                  KRISTEN APPROVED!
                  Vice Prez.
                  Team Black...TEAM EMO
                  Come on kids! Get a Calendar!
                    Re: oil leak?
                    for future referance, what do you need to do you pull the oil pan gasket? just jacking up the engine to clear the k-member is enough?
                      Re: oil leak?
                      That, or a tubular K then it is real easy.
