synthetic oil - FirebirdV6.com/CamaroV6.com Message Board
synthetic oil
  • synthetic oil
    2 oil changes ago I started using full synthetic quaker state 10w30. The last oil change by mistake I used synthetic blend quaker state 10w30. I heard your not supposed to go back if you have used the full synthetic. So I changed my oil yesterday and I have no leaks what so ever. And I again used the FULL synthetic like I should be. Do you think my car is ok?
    it should be fine. i just had to do a oil change on my car after the cam install. had to get the tidbits out. i put in 15w-50 mobil 1 tri-synthetic. you will be fine with whatever oil you put in. as long as its oil
    For Sale<p>Mods so Far:<br />Tb Coolant Bypass, NGK Vpower Plugs, Accel 8mm Wires, Gutted Cat, TransAm Muffler, K&N FIPK, Crower Baja Cam, Comp Cams Magnum Rocker Arms 1.52 Ratio, Ported Throttlebody, Ported Intake Manifold, 3.73s and Auburn LSD, Yellow Underbody Neons, Milled Heads, Pacesetter Headers, TransGo Shift Kit, 1 Piece DS, Accel Coils, Rk Sport Air Temperature Module<p>Soon Mods:<br />Nos 5175, Rims, Stage 2 Jet Chip, Jet Underdrive Pullys, Strut Tower Brace, Subframe Connectors, Speed Calibrator, Lowering Springs
      My dad's vette has run cheap castrol before...just cause we had too, it works great still!
      2001 3.8l<br />Monsoon 500 watt<br />Automatic tranny<br /><a href=\"http://members.cardomain.com/1hotv6\" target=\"_blank\">http://members.cardomain.com/1hotv6</a>
