It is normal to always have water condesation build up in the oil cap? It is always there after a few days of driving. Its not a light sprinkle, nor a heavy soak, just H2O there always.
condesation in oil cap
Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.Tags: None
Re: condesation in oil cap
its mainly clear. there are sometimes a smidgen of cloudy oil off white speckles. not much. how much of the top part of the engine do you have to take off to change out the intake gaskets?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
so i should do the intake gasket then probably...?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
Originally posted by HeadyFirebird'00 View Postits mainly clear. there are sometimes a smidgen of cloudy oil off white speckles. not much. how much of the top part of the engine do you have to take off to change out the intake gaskets?
basically when you are done just the block and pistons are going to be there
You need to take the heads off to take the intakes off? I've been doing it wrong all these years? Wow. I usually just take off the lid and tubing, pull the alternator out, fuel rail bolts, MAP sensor, remove fuel rail, remove coil packs as assembly, unbolt upper intake, unbolt lower intake, voila.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Originally posted by Bird_Of_Prey View PostYou need to take the heads off to take the intakes off? I've been doing it wrong all these years? Wow. I usually just take off the lid and tubing, pull the alternator out, fuel rail bolts, MAP sensor, remove fuel rail, remove coil packs as assembly, unbolt upper intake, unbolt lower intake, voila.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
SO its bad for condesation in the oil cap?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
I'd monitor the oil and coolant to see if there are any changes. If it's just building a little moisture, I wouldn't worry. If the oil starts looking milky, then I'd worry.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...9 hours ago
