Whining Noise - FirebirdV6.com/CamaroV6.com Message Board
Whining Noise
  • Whining Noise
    When I hit about 35MPH, I start getting this steady whining noise coming from what I think is the wheel. The pitch of this noise increases with speed and is unaffected by RPM.
    Whatcha think? Wheel bearing?
    Lounge Moderator
    Re: Whining Noise
    Wheel Bearing would be my guess... or warped rotor causing the rotor to rub but i wouldn't call that a "whining noise" exactly...
    Y87 Package
    MOGOB APPROVED!
    BONE APPROVED!
    VANBIBBER APPROVED!
    KRISTEN APPROVED!
    Vice Prez.
    Team Black...TEAM EMO
    Come on kids! Get a Calendar!
      Re: Whining Noise
      Yeah, this is a very constant, smooth whine.
      Lounge Moderator
        Re: Whining Noise
        Get it in the air and turn the wheels...
          Re: Whining Noise
          That will work. Sometimes a bad wheel bearing will heat up after a short drive too.
            Re: Whining Noise
            The noise doesn't start until I go over 35MPH.
            Lounge Moderator
              Re: Whining Noise
              HOw old are the tires?
              High Pitch or Low Pitch Whine?
              Y87 Package
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
                Re: Whining Noise
                The tires are pretty old.
                The pitch is probably a little lower than that 1K test tone you here on TV sometimes when they have the color bars up.
                Lounge Moderator
                  Re: Whining Noise
                  I've worked at tire shops before, sometimes when tires get old and start to wear down, they'll wear in odd ways and start to cause a low whine.... Does it get louder as you increase speed?
                  Y87 Package
                  MOGOB APPROVED!
                  BONE APPROVED!
                  VANBIBBER APPROVED!
                  KRISTEN APPROVED!
                  Vice Prez.
                    Re: Whining Noise
                    Yes, louder and higher pitched. Very noticeable too. The tires on the front are cheap and crappy too. Like some Nankangs, or something like that.
                    Lounge Moderator
                      Re: Whining Noise
                      Yeah, your best bet to find out if it's a wheel bearing or tires is to throw it in the air and get the wheels going...if it's a wheel bearing it'll make noise...tires wouldn't if it's in the air....at least that's my .02 ... is the car handling oddly or anything like that?
                      Y87 Package
                      MOGOB APPROVED!
                      BONE APPROVED!
                      VANBIBBER APPROVED!
                      KRISTEN APPROVED!
                      Vice Prez.
                        Re: Whining Noise
                        Nah, it seems to handle fine. But then again, I just did all this suspension work, so if it is off, I probably wouldn't notice as much.
                        Lounge Moderator
                          Re: Whining Noise
                          never asked, front or rear wheel? Doesn't sound like a differential whine, does it?
                          Y87 Package
                          MOGOB APPROVED!
                          BONE APPROVED!
                          VANBIBBER APPROVED!
                          KRISTEN APPROVED!
                          Vice Prez.
                            Re: Whining Noise
                            Not sure which wheel. I'll need to get someone to ride with me to listen closer. I'm not sure what a differential whine sounds like. I just had the diff serviced a couple weeks ago and the guy said everything looked fine.
                            Lounge Moderator
                              Re: Whining Noise
                              differential whine is a low pitched, kinda drony whine, that advances with speed as opposed to RPM, it happens usually when the pinion nut backs off, or when the bearings go.... happened in my grandfather's silverado...it'll have a little bit of a whirring noise, not unsimilar to what a t-5 sounds like when you put it in reverse, just a little higher pitched.
                              Y87 Package
                              MOGOB APPROVED!
                              BONE APPROVED!
                              VANBIBBER APPROVED!
                              KRISTEN APPROVED!
                              Vice Prez.
