Whining Noise - FirebirdV6.com/CamaroV6.com Message Board
Whining Noise
  • #61
    Re: Whining Noise
    Originally posted by Firebirdkid96 View Post
    i think you should say screw this **** and just put a 3.42 posi rear out of an s-10 up in it.
    Can you tell me exactly what I would need to do this? This is what I want, but know almost nothing about the mod.
    Lounge Moderator
    • #62
      Re: Whining Noise
      well you have two routes.
      a. get a rear from an s-10 and it bolts right up in place of what you have.
      I don't know if the hubs are the same, i can find out though if this is the route you want to take. s-10 rears are auburn LSD already. only thing you'd need are a set of gears, i suggest 3.42 or 3.73 if they are your daily driver. I have 3.42's and it gives quite a bit of pick up, kristen has 3.73's and that really kicks the car in the a** when she lays into it from when i rode in it, but then again she also has a more mods than i do.
      or, you can take your diff out of your rear, spend $500 on an auburn LSD, and another $250 on the gears. and then put those in it.
      the s-10 pull is def. the cheaper route to go though.
      let me know what you'd prefer and i'll get you more info on it.
      Y87 Package
      MANUAL CONVERTED, Pro 5.0 Shifter
      Pacesetters, Magnaflow Cat, Cutout, Flowmaster
      MOGOB APPROVED!
      BONE APPROVED!
      VANBIBBER APPROVED!
      KRISTEN APPROVED!
      Vice Prez.
      Team Black...TEAM EMO
      Come on kids! Get a Calendar!
      • #63
        Re: Whining Noise
        I prefer cheaper. Are you telling me the rear axle on an S-10 is the same as a Camaro, or are you just talking about the guts inside the diff?
        Lounge Moderator
        • #64
          Re: Whining Noise
          pretty sure the whole axle is.
          Y87 Package
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          • #65
            Re: Whining Noise
            3.73 and LSD should would make me happy.
            Lounge Moderator
            • #66
              Re: Whining Noise
              I'm not positive on this, but I'd say about 95% that the whole housing wouldn't transfer. Correct me if I'm wrong, but S10s are a leaf spring rear suspension, which would not have coil spring perches, not to mention torque arm, panhard bar, or control arm mounting brackets.
              -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
              • #67
                Re: Whining Noise
                just checked, s10s are a gm 10 bolt, but yes, you still need your axle. just go get the diff out of one for $80 and pick up a set of 3.73s
                Y87 Package
                MOGOB APPROVED!
                BONE APPROVED!
                VANBIBBER APPROVED!
                KRISTEN APPROVED!
                Vice Prez.
                • #68
                  Re: Whining Noise
                  3.73 LSD on an M5 should make for an interesting ride.
                  Lounge Moderator
                  • #69
                    Re: Whining Noise
                    Either way, since I don't think I'll have much to do for the next couple of days, I'll tear down one of my spare 10 bolts and do a little write up with pics on replacing the crush sleeve.
                    • #70
                      Re: Whining Noise
                      Yeah, I would appreciate that. I'm not going to be able to do the LSD right now. First things first... fix the car.
                      Lounge Moderator
                      • #71
                        Re: Whining Noise
                        couple that with 221 N/A RWHP lol
                        Y87 Package
                        MOGOB APPROVED!
                        BONE APPROVED!
                        VANBIBBER APPROVED!
                        KRISTEN APPROVED!
                        Vice Prez.
                        • #72
                          Re: Whining Noise
                          How does one go about getting an easy 221?
                          Lounge Moderator
                          • #73
                            Re: Whining Noise
                            either find a factory freak,
                            or, with your 2000, throw on some pacesetters, hi flo cat, catback exhaust a k&n fipk or whisper lid. that should put you at around 220 crank from the numbers ive seen here..., a 1le driveshaft will get more of that to the wheels....
                            Y87 Package
                            MOGOB APPROVED!
                            BONE APPROVED!
                            VANBIBBER APPROVED!
                            KRISTEN APPROVED!
                            Vice Prez.
                            • #74
                              Re: Whining Noise
                              Currently, I have a K&N, hi flo cat and magnaflow catback. Wonder what that's doing for me.
                              Lounge Moderator
                              • #75
                                Re: Whining Noise
                                just the K&N filter or the actual FIPK?
                                you already have tubular manifolds so headers wont be much of an upgrade.... you're prolly looking at right around 210 - 215 wheels with your current setup on a whim....
                                Y87 Package
                                MOGOB APPROVED!
                                BONE APPROVED!
                                VANBIBBER APPROVED!
                                KRISTEN APPROVED!
                                Vice Prez.
                                • Andy H
                                  Transmission removal help!!
                                  by Andy H
                                • 2.8 Bird
                                  Abs inop
                                  by 2.8 Bird
                                • fishin
                                  by fishin
