high oil pressure - FirebirdV6.com/CamaroV6.com Message Board
high oil pressure
  • high oil pressure
    does anyone know where the test port for the oil pressure is on a 2001 camaro? lately my oil gauge has been fluxuating, when the car is being driven it reads at slightly higher than 60 but when i first tap on the gas it rises all the way up to 120 and stays there for a bit, any ideas whats going on?
    Re: high oil pressure
    hmm maybe just remove the actual oil pressure sensor and use that?
    TEAM C6V6
      mine does the same for a few days after i change the oil and filter
      2001 Camaro 3.8 A4
      1991 3000GT VR4
      2001 Mitsubishi Eclipse GS
        You can't give me a little pressure?
          sounds like a faulty pressure sensor, if you wanna test it, that'd be the place to do it
          Y87 Package
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
          Team Black...TEAM EMO
          Come on kids! Get a Calendar!
            Just hook up a mechanical gauge and use that to read the pressure. If it differs from what you normally get, then you have a bad sender. If it reads the same, then you've got problems. But it's probably the sender just acting goofy.
              yeah thanks guys it ended up being a faulty sensor swapped it out and it reads normal now thanks for the help
