EVAP System - FirebirdV6.com/CamaroV6.com Message Board
EVAP System
  • EVAP System
    What is more likley to cause the smell of gas vapor in the cabin, a bad Vapor Canister, or a bad vapor purge valve, or bad vapor selinoid? Or all three.
    Car threw P1441. And now I am getting gas fumes in the cabin.
    After reading this thread Caninster Purge I am pretty sure what I need to do to find the problem.
    From the above I know how to test the valve for a bad canister, is there a way to test the valve and seleniod.
    If it is a bad canister, the manual says I should clear the vacums lines with the EVAP tool thingamajig with nitrogen. I don't have a that special tool, will compressed air work.
    oh yeah....96 3.8 Bird.
    Cardomain
    Re: EVAP System
    i would think that it's the canister. i had both go on me at different times. i got the bad fuel smell when it was the canister.
    the seleniod is held on with one bolt, one clamp line and one wire harness. takes all of 1 min to take out and put back in. so to test it...i just got a new one and changed it. that wasn't my problem so just put my old one back in and returned the seleniod. did that all in the autozone parking lot!
    WAWA-A-HOLIC
      Re: EVAP System
      instead of compressed air, you could try those cans of computer duster. They are about $4 and composed of nitrogen and r4.
        Re: EVAP System
        Well since the car is falling apart and its my wifes daily driver we just gotta get it to past smog one more time and its getting traded in later this summer. She wants a CRV :( ... I got a code reader, so I should be able to delete the codes, and as long as it past the sniffer we should be good.
        Cardomain
          Re: EVAP System
          a 96 bird wolnt use a sniffer, the emissions is checked with the OBDII system
          if you clear the codes, it goes into relearn mode, and is an auto fail
          at least thats how it is here, not sure how it is in your state
            Re: EVAP System
            Did you ever fix this error code? I'm seeing the EXACT same thing and I'm assuming you had to find a fix by now?
              Re: EVAP System
              Just an update...
              I'm pretty sure I'm one of the lucky ones that had this SES light go off due to the gas cap not being threaded properly. The light went off (~4 hours ago) and I took it to get it inspected right away -- it passed!
                Re: EVAP System
                Well it over two years later. We got the crv and now the bird is my daily driver. After I cleared the code. It didn't come back. I just the the code again today , so I think I will clear it again and hope for the best. I have passed Cali smog two times since my initial post.
                Cardomain
                  Re: EVAP System
                  I have taken mine out and HPtuners it. LOL I have a little checker auto parts air filter on the hose end from the canister.
                    Re: EVAP System
                    I've unplugged the EVAP **** a long time ago. Worthless if you ask me.
                    1995 Pontiac Firebird
