overheating and fan problems - FirebirdV6.com/CamaroV6.com Message Board
  • overheating and fan problems
    idk if this is normal or not but my tempeture rises to about 240 250 and then my fand kick but for only a little bit they turn off when the temp hits about 210 i think there coming on too late, think there somethign wrong with my fans. i have a 97 rs 3.8
    Re: overheating and fan problems
    Your temp sensor may be bad and giving inaccurate temps. You can test it to see if the resistance values are where they should be
      is the the one that is located somewhere under the trothel body not directly under some where around there if it is i just replaces that one for the same reason that my fans where not kicking so i changed it but the same prob is happening
        check fan fuse and relay.
