Busy Day - FirebirdV6.com/CamaroV6.com Message Board
Busy Day
  • Busy Day
    I worked on the bird a bit today.
    I changed the coolant, cleaned the electrical grounds/battery terminals and installed my new MAF screen.
    Pretty painless as stuff goes but I may have sucked at flushing the coolant.
    I don't think I got the old stuff out of the thermometer? I don't know. I think I flushed about 2 gallons then replaced it with antifreeze. So now I have way too much antifreeze compared to the amount of water I have. Not sure its gonna matter much though.
    anyway, with the new MAF screen the car feels way more confident. The old one was shot to hell. I wish I had taken a picture of it. All those little vanes were bent and restrictive-looking.
    I cleaned 4 grounds, because thats all I could find (?) and I didn't have any more corrosion protection gunk, so I wiped a little bit of wax on top of em.
    Re: Busy Day
    if you want to flush it again, just empty it, and stick a hose in there. let it fill. then drain it. after its drained, fill it with water again. keep doing that till it look clear. then just fill it with coolant!
    WAWA-A-HOLIC
      Re: Busy Day
      Yeh i might try again this weekend
      • Andy H
        Transmission removal help!!
        by Andy H
      • 2.8 Bird
        Abs inop
        by 2.8 Bird
      • fishin
        by fishin
