Starter Help - FirebirdV6.com/CamaroV6.com Message Board
Starter Help
  • Starter Help
    Im 90% sure my starter is stuck, battery is good. car has gas. when i go to start it i get one click then nothing.
    can someone please tell me where the starter is on a 1997 3.8L Camaro so i can tap it with a screwdriver. I cant find any pics anywhere.
    Re: Starter Help
    right next to the oil pan on the drivers side. it should have a shield over it.
    could be the relay going on you.
    WAWA-A-HOLIC
      Re: Starter Help
      Make sure there is no corrosion at the battery terminals.
        Re: Starter Help
        Make sure your side terminals on your battery aren't stripped.
        but the starter in on the driver's side of the engine, you'll have to take off the heat sheild.
        I need to put my heatshield back on.
        Y87 Package
        MOGOB APPROVED!
        BONE APPROVED!
        VANBIBBER APPROVED!
        KRISTEN APPROVED!
        Vice Prez.
        Team Black...TEAM EMO
        Come on kids! Get a Calendar!
          Re: Starter Help
          if its stuck, its safe to just tap it with a screwdriver to get it working again right?
            Re: Starter Help
            it might work, but uh, it's def. safe.
            Y87 Package
            MOGOB APPROVED!
            BONE APPROVED!
            VANBIBBER APPROVED!
            KRISTEN APPROVED!
            Vice Prez.
              Re: Starter Help
              tapping it with a screwdriver isnt going to do anything, you need to hit it with a hammer
                Re: Starter Help
                the starter could be totally fryed on you. mine was at 84,000. i had everything to go, but the starter wouldnt engage. take it out and have it tested and an auto parts store. there are many that can test them...
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
