worst possible outcome? - FirebirdV6.com/CamaroV6.com Message Board
  • worst possible outcome?
    so i was trying to get my car started today because the starter was stuck...my idiot friend decided to jump the car but REVERSED the cable and put + on - and - on +.....it fried something cuz now my car gets no power...i have no idea what this means and as of now my car is just sitting here...any help as to how to fix this would be GREAT. thanks
    Re: worst possible outcome?
    check your fuses
      Originally posted by Meatyshells View Post
      check your fuses
      always.
      if it is an electrical problem just start at the fuses
        damn.....i never heard of anyone oding that before....lol..GL
        ....WHITE CAMARO CLUB....? =(
          may have blew a fuse, or melted a wire
          the worst possible cause is a fried computer
            thats what i thought. thank you
              Geesh why don't you try P&P'ing your heads by putting a sandblaster in your intake. Works great everytime.
                Any updates?
                Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
                  Had this happen to me with a durango my mom was giving me a jump and my dad had replaced the battery connectors with 2 black wires. Bam blew the big honking fuse in the fuse box but nothing else. Turns out my CPU took all the juice and it was toast also killed a couple ac fuses. After 1k for a new computer and towing my ac was still shot and the new cpu acted wacky. Traded in the car right after i replaced the CPU rolling a bunch of negative equatity but really had no choice car was a mess after that. Make sure you check everything and go to somone who knows what they are doing, if you have problems electrical stuff is never easy
                    still awaiting the verdict...should know tomorrow morning.
                    • Andy H
                      Transmission removal help!!
                      by Andy H
                    • 2.8 Bird
                      Abs inop
                      by 2.8 Bird
                    • fishin
                      by fishin
