Hey everyone I'm looking for a little advice. I have a '96 camaro w/ a 3.8L. I'm currently having a abbott cam installed and I was wondering since the timing has to be advanced what timing chain would work the best and fit. I have looked at a few like the JP and rollmaster but want to be sure Im gonna buy the one that will work out best. Any advice I appreciate. Thanks Jeremy
Timing Chain
Re: Timing Chain
Having your timing advanced has nothing to do with the timing chain. The timing is adjusted thru the PCM via HP Tuners. The only reason to get a new timing chain would be to replace the stock one with a double roller due to heavier valve springs (130 lbs or higher). With that cam you will need at least 105 lb springs, but those wouldnt require a double roller.
I've good things about both the JP and Rollmaster. I have a Rollmaster double roller.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: Timing Chain
Originally posted by Shodown View PostHaving your timing advanced has nothing to do with the timing chain. The timing is adjusted thru the PCM via HP Tuners. The only reason to get a new timing chain would be to replace the stock one with a double roller due to heavier valve springs (130 lbs or higher). With that cam you will need at least 105 lb springs, but those wouldnt require a double roller.
Re: Timing Chain
i've heard good things about both the JP and the rollmaster double chain.Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: Timing Chain
https://www.zzperformance.com/grand_...=388&catid=104
I dont know where to get the JP.
What valve springs are you installing along with the cam?sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: Timing Chain
yeah zzperformance was prob where i was gonna get it if i couldnt get my hands on one.........ummm for springs i was thinkin 105 or 130.....w/ the 130's you are better to run the double roller correct????......how hard are those to install??
Re: Timing Chain
Originally posted by Liggs96V6 View Postw/ the 130's you are better to run the double roller correct????
Originally posted by Liggs96V6 View Posthow hard are those to install??
From what I can tell, its not that difficult just time consuming. FYI, you will need a milled oil backing plate, and a stock OEM paper replacement timing cover gasket (not the metal Felpro gasket!).
Im sending you a PM with info from FTV6. There is a great thread about it with lots of info.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: Timing Chain
Originally posted by Blizzard242 View PostRollmaster, from what I've heard, have no problems with fitment or the need for a milled oil cover. I checked and checked when I installed mine and it doesn't appear to be rubbing at all.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Re: Timing Chain
There's a lot of guys on the 3800 forum with the same question. I found a thread specifically about this here http://www.3800pro.com/forum/cams-he...clearance.html
I don't know how the l36 differs from the l67 though which is what they're dealing with. Majority of the people that installed them did no machining without problems. But like I said, I don't know how the l36 differs from the l67.
I also used a single felpro front cover gasket with no leaks.
TEAM C6V6
1997 Camaro RS A4
2006 Chevy Colorado
Re: Timing Chain
Someone help me out with this: what exactly is the clearance issues you're having with a double roller? Won't milling the timing cover move everything further back, therefore making it even more cramped (milling is the removal of material, so it'll stick out less)?~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...4 days ago
