just installed LS1 injectors...and no they will not directly snap in and bolt on....fuel rail needs to me modified.....the LS1 injector's O ring sit a little higher then our stock ones and the brackets need to be shorter on all 4 brackets.
In your opinion, what all would happen if someone didnt shorten the rail and just put the ls1 injectors in? Would they have a fuel leak? What noticeable differences would there be if the rail isnt shortened, just curious because i have ls1 injectors and mine dont leak and when i sat the 3.8 and ls1 injuector side by side they were the same length, the ls1 injectors are just thinner
those stock injectors look VERY close to what a dsm's stock injectors look like... you should have done some reasearch to see if a set of Fuel injector clinic injectors would have worked.
91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
oh wow, i thought they just bolted in place, i could not figure out why you imed me telling me you got it installed, lol.
and by the way.. i don't want an auto [img]tongue.gif[/img]
Ryan
1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
well mine have been in for many months no leaks yet, what else could happen if they are too short? would i know if mine were to short by now? would the car run rich/lean if they are too short or would they just leak? mine do not leak but now you have me worried
