engine runs absolutely horribly - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: engine runs absolutely horribly
    i hate to say it but i think you otta redo what you did, and take it all apart and put it back together with some finness'
    • #17
      sounds like one of the cylinders isn't firing, could be a coil pack, did you get it wet at all?
      don't waste your money on guessing, guessing usually costs more than taking it to a pro in the long run.
      • #18
        nope, dont want to take it to a pro! haha well i was random troubleshooting. changed all the coil packs with my dad's 94 bonneville (they use the same luckily) and no change. so we started checking plugs...plug wires...the works. going cylinder by cylinder and fireing her up after each check. then one time the idle went from crap...to completely normal. just evened out randomly. the only guess we have is that when we took the fuel rails off all the fuel was drained out, so air replaced it. and when we put them back on the air remained inside them and the fuel lines...so when we fired it up there was air in the lines so the injectors couldn't put out the right amount of fuel causing it to run like crap till all the air was pushed out and a steady stream of fuel was established...sound crazy?? i dont know...just the hypothesis. the car runs fine though! :D took her out for a spin and everything was great. before my boost gauge was bouncing all over the place at idle, and now it hold steady at 20 vacuum like normal. idle is strong and drives perfectly.
        thanks for throwing out ideas though
        1999 Firebird Y87/W68
        • #19
          glad to hear it worked out! I guess next time the fuel rails need to be loaded or something.
          • #20
            you probably singed a wire or something
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
