NGK makes these o2 sensors... - FirebirdV6.com/CamaroV6.com Message Board
  • NGK makes these o2 sensors...
    I think i found a good buy and cheaper price for some o2 sensors for pre-cat and post i think. But they look different... check out the little pics.
    http://www.ngk.com/results_app.asp
    the results might not work you may have to go thru the car select thingy.
    but i have to check which ones i would need either the 2 wire or the 4 wire. They dont have the usual covering on the end that sits inside the pipe. These seem like good stuff, but i need a second opinion..
    this is for those out there interested in replacing your o2 sensors.
  • Andy H
    Transmission removal help!!
    by Andy H
  • 2.8 Bird
    Abs inop
    by 2.8 Bird
  • fishin
    by fishin
