11 codes - FirebirdV6.com/CamaroV6.com Message Board
11 codes
  • 11 codes
    DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
    DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
    DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
    DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
    DTC P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
    DTC P0300 Engine Misfire Detected
    DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
    DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
    DTC P0420 Catalyst System Low Efficiency
    DTC P1651 Fan 1 Relay Control Circuit
    DTC P1665 Driver 3 Line 5
    i did a search on most. i cant remember which one but i heard one is from my manual fan switch. which one is it?
    i have a bad coil pack so that explains Engine Misfire. i have no cat so that explains one.
    i'm about to change a fan relay so that should clear up the DTC P1651 Fan 1 Relay Control Circuit
    do i need a new maf sensor?
    how do i fix the others?
    Re: 11 codes
    clear the codes, and see if they come back
    they might be those little freak things that happen once
      Re: 11 codes
      Well I don't have degree in electrical engineering but
      sounds like a safe bet
        Re: 11 codes
        holy ton-o-codes batman.
        at least they are easy to fix.
        WAWA-A-HOLIC
          Re: 11 codes
          how do i fix them? when they say low voltage .. does that mean i need new sensors?
