Ok. I have a 1998 3.8 Firebird and just replaced the tension assembly and oil pressure sensor. Tensioner was worn out, belt slipped, hit the sensor. But after all this is fixed the car has a huge power loss. It runs fine for abour 2 or 3 minutes. Then you can kick the car down and it will just rev to about 3500 rpms and will not put any power out. Im lucky to get 60 mph. Oh and Diagnostics test said cylinder misfire, but plugs and plug wires were replaced about 3 months ago. Anyone know if running it while the oil pressure sensor is bad will cause a plug to foul? Im thinking it could be fuel pump or injectors =\. Im just hoping its not going to cost a lot to fix as its just messing up at the worst time =\
HUGE power loss
Re: HUGE power loss
Originally posted by winnipegcamaro View Posti jsut had a problem with my engine boggin down on accel, it was a bad cat converter for me so check that, after that check coil packs. gl
Re: HUGE power loss
went to midas and got mine changed 2 days ago and the guy brought me under the car and banged on the cat with his hand and i could hear broken peices and a rattle. so u can try it yourself to hear for the sound or take it to a muffler shop they can replace it for you. buy a high performance one to replace the stock bs before though.
Re: HUGE power loss
Originally posted by winnipegcamaro View Postwent to midas and got mine changed 2 days ago and the guy brought me under the car and banged on the cat with his hand and i could hear broken peices and a rattle. so u can try it yourself to hear for the sound or take it to a muffler shop they can replace it for you. buy a high performance one to replace the stock bs before though.
Re: HUGE power loss
http://cgi.ebay.com/ebaymotors/94106...spagenameZWDVW
Stock will be a lot more.
Just find out if its the cat.
Re: HUGE power loss
if you dont know what you're doing with exhaust take it to a shop, there's alot going on by the cat... make sure its the cat before you do anything
if you have a misfire code, that cat won't throw that. there's another problem.
crank position sensor?Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: HUGE power loss
ONLY DO THIS IF THE CAR HAS BEEN SITTING! The cat (exhaust for that matter) gets very very hot.
Disconnect the pipe behind the cat. If you're on stock exhaust, it'll be a slip fit connection.
Look inside the cat to see if the peices are broken up. If you want to gut the cat while you're down there, Jam a pipe into the thing a few times and remove the peices as they break off - then start the car and revv it a few times with the pipe disconnect to clear the small peices out.
Make sure to tell us if this fixes your problem. ;)
Re: HUGE power loss
Originally posted by Pathogen View PostONLY DO THIS IF THE CAR HAS BEEN SITTING! The cat (exhaust for that matter) gets very very hot.
Make sure to tell us if this fixes your problem. ;)Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Re: HUGE power loss
Originally posted by Firebirdkid96 View PostYour stock cat to S-Pipe connection was slip fit?
*thinks... maybe that was after the S....
Doggonit-- now I'm starting to think that was my 3.4....
Originally posted by fire98bird View PostIve decided Im just gonna cut the cat off and either straight pipe it or gut the cat. Can anyone help me out here, cuz Ive never fooled around with that stuff? Places to cut and whatnot.
Re: HUGE power loss
Originally posted by Pathogen View PostIn my 2000 is its. The sucker kept falling off the car when I was driving!
Second thought, take it to a shop.... but tell us which code the car is throwing.
If it's a random misifre code I'm willing to bet you either a. have bad ignition components somewhere and the car REALLY is misfiring or,
the car isnt misfiring at all, your crank position sensor is bad, or the stator in the harmonic dampner is bent.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Re: HUGE power loss
Originally posted by Firebirdkid96 View PostLol, only reason I ask is because I happen to have my stock exhaust from manifolds back to I pipe sitting in my garage off of my 96, and the S-Pipe i welded to the cat with the trans mount bracket on it.
and MayBad for the exhaust thing.... dang it's been a while since I really thought about stock exhaust. lol
