Car hesitating to start - FirebirdV6.com/CamaroV6.com Message Board
  • Car hesitating to start
    what else could it be besides the starter? could a bad coil pack cause it?
    it just turns for 4 seconds then starts up
    Re: Car hesitating to start
    Battery.. lol
      see above. ;)
      Check (in this order)
      battery connections
      ground connections
      take battery to Autozone (or similar) and have tested
      spark plugs
      plug wires
      coils
      Ignition Control Module (ICM)
      Stop checking when problem is fixed. ;)
      oh, it could also be your ignition lock cylinder, but I highly doubt it. :D
        fuel pressure regulator. do a search. i changed mine car fires up like a champ everytime
          I had the same problem, and it was the fuel pressure regulator also...
            a failing fuel pump could also be added to the list I believe. But then there would be other symptoms past just startup too.
            TEAM C6V6
              I have a problem with my 1999 firebird 3.8 starting also. I put the key in and turn it and sometimes, most times she starts, but sometimes its hesitant than turns over, and occasionally you turn the key and nothing but dashboard lights. the security light does go off, so I ruled out that. I've been reading the threads and some are seem to be like mine., but not sure. It's not the starter or battery, or relays fuses. I thought maybe the neutral safety switch, but rulling that out also, due to she starts the same way in park as in neutral, hesitant. I thought maybe the ignition switch, or the ( ICM ) Ignition control module. But not sure if thats the same thing or are they two different parts? Also if there is a ignition switch, where is it? and also the ICM, I saw in a post they said it was behind the coils, but I can not see it looking in ( Allthought the coils are there, or is it hidden underneath them? Any help would be great! Thanks
                where is the fuel pressure regulator located at?
                  the starter has nothing to do with the car not starting
                  if the engine turns over, the starter isnt the problem
                    fuel filter too
                      The coils are on top of the ICM. One bolt in front and one in back if i remember correclty holds it and all the coil packs in place.
                        i changed my fuel filter.
                        i know where the coil packs are. wheres the fuel pressure regulator?
                          To the left of the coil packs a little further back on the fuel rail. It'll have a vacuum line on it too.
                          TEAM C6V6
                            changed my fuel pump and it cranks right up now.
                              the fuel press reg is in a bell shaped housing near the back of engine on top on the passenger side. the fuel rails connect to it. and there is a vacuumm line that there too
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
