Subject says it all. Car is a 95 3.4L Camaro. It was a hot day today in Riverside, CA and A/C was not cooling enough. So I figured freon needs to be charged. Bought a refill kit with guage and that's what it read. Tried 2 guages, both read the same. So I did not proceed with the refill. Anyone got any ideas on why this is? Will this create any problems with the engine? Any help appreciated. TIA.
100+ PSI on Low Pressure Side of A/C
Re: 100+ PSI on Low Pressure Side of A/C
evac the system and take it outY87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Yes and No. If you are getting a high reading on the low side port but the compressor is not turning, then something else is wrong. Do NOT try to put freon in the low port if you have a high pressure reading. I cannot tell you what could happen because the moderator will sensor my post (as they have before, which I'll never figure out, but I digress...) but lets just say that the pressure is beyond the pressure safety factor the can was designed for, you can read the safety warnings on the can for more information.
If the compressor is not turning with a high pressure on the low port side, then you will need to try to troubleshoot the electrical system (pressure sensor, wire to the A/C clutch etc).
I'm looking at your post again... I thought you said it read high, but now it doesn't say that. So I don't know what to say...
checked the pressure yesterday and it was normal. ~30 psi is what I got from 2 guages. compressor was engaging on and off, when off, pressure goes to ~40 psi, when on, ~30 psi. is this normal? what could have caused the pressure to go up to 100 psi the other day? now, seems like everything is normal though.
Not sure what would cause it to spike to 100 psi. If it's now normal, and blowing cold (not just cool) air, then I would just keep an eye on it for a while and check the pressure frequently. If it seems OK after a while, then don't worry about it.Last edited by Rob Bell; 07-11-2008, 07:16 AM.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by motoservdog View Postchecked the pressure yesterday and it was normal. ~30 psi is what I got from 2 guages. compressor was engaging on and off, when off, pressure goes to ~40 psi, when on, ~30 psi. is this normal? what could have caused the pressure to go up to 100 psi the other day? now, seems like everything is normal though.
If it's blowing cold, don't mess with it.
I'm not sure exactly where the exact location of the sensors are, but they will be along the pipes. The larger pipe is the low pressure side. There may only be a high-side sensor, though.
Forgot to mention, that you do not want to jump the sensor to start the compressor because of low pressure. When you start charging the system, when the pressure builds enough from adding refrigerant, the compressor will start by itself.Last edited by Rob Bell; 07-10-2008, 10:22 PM.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
