Heat is not working ideas? - FirebirdV6.com/CamaroV6.com Message Board
  • Heat is not working ideas?
    Ok well Just got my 02 Dodge ram witch is pretty sweet. We got some snow the other day I went out to clean off the maro and it was running for like 10 mins the engine was at 220 temp wise and cold air was still blowing out but once I turn the dial from defrost to blow out the vent it was still cold but the temp gauge dropped to 190. I am thinking it may be the thermostat. What do you guys think thanks in advance for your guys help?
    1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.
    Are you talking about a camaro or a dodge? When you turned the dial from defrost to blow out of the vents and the temp gauge dropped to 190, did the hot air start blowing?
      Im not sure how the heat actually comes on. I dont know if there is a valve or not, But it sounds like if there is a valve that the valve that opens to let the hot water into the heater core is not opening.
        Check your radiator fluid, it may be low.
        Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
          The camaro I am talking about umm we change the thermostat out and added a lil antifreeze and it seems to be working now. O knows I have to sell it since I can't afford both cars.
            you probably had air in the coolant lines.
            Follow me!
            Or this
              sell me the GFX kit!
              Mystic Teal Metallic
              • 187shark
                by 187shark
