What is this, see pic - FirebirdV6.com/CamaroV6.com Message Board
  • What is this, see pic
    What is this called, I took it off to clean my IAC and when i put it back on it split right down the middle. I know its a vacuum thing, but whats the name of it so i know what to look for. Also the iac is on the engine its self, what it the other thing thats is right in front of the vacuum line? Does it ever need cleaning? http://spaces.msn.com/members/Bobbyz72/PersonalSpace.aspx?_c11_PhotoAlbum_spaHandler=TWlj cm9zb2Z0LlNwYWNlcy5XZWIuUGFydHMuUGhvdG9BbGJ1bS5GdW xsTW9kZUNvbnRyb2xsZXI%24&_c11_PhotoAlbum_ spaFolderID=cns!1pVq4VczLi7Wl2sQK8ii8ogg!153&_c=Ph otoAlbum
    I was bored today is the reason i cleaned my iac. I have NOT had any idle problems i jest wanted to clean it because i have heard of other people having to cleaning theirs. I cleaned the iac and as far as i could reach where it sits inside, let me tell you, I didnt know my car would idle this well! [img]graemlins/banana.gif[/img]
      EVAP purge line.
      Matt
      1998 Mystic Teal Camaro M5
        yes, thanks, do you have any idea where i can find that rubber adapter?
          6 days ago
