Was going to the store today when i realized that my oil pressure was very low, between the 1st marking and the 1/4 point. I quickly pulled over, saw smoke from my hood, and the smell of burnt oil. Open the hood lots of oil on the bottom part of the engine bay, also leaking onto the ground. Think one of my gaskets went bad or something? I need the car by tomorrow, so if i could get some suggestions quickly, that'd be helpful.
No oil pressure, leaking everywhere.
Re: No oil pressure, leaking everywhere.
Well, you need to pinpoint the oil leak. Generally a leaking gasket won't cause an oil pressure drop. What year/engine are we dealing with? Guessing that it's a 3.8, I would first look at the oil pressure sensor. It's on the front of the motor above the oil filter. An oil leak there will cause a pressure drop, and make a big mess.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
If you recently changed your oil, make sure the pan bolt is tight. That the oil filter is on tight. Also, check to see if the filter has a gasket or not doubled up.
Did you hit anything? Any puntures on your oil pan? Are you leaking from the pan gasket itself? Are you leaking from the oil level sensor?
Need help here finding out if what holds the oil pressure sending unit is acutally a part of the block.....
EDIT:
Found out its a part of the oil filter adapter(where you screw your oil filter on to)
Any help with a part # or where to find it??Last edited by Crazed98Camaro; 06-04-2008, 08:18 PM.
Called the dealer this morning, says its a special order part... 6 days to ship.... screwed.
In the meanwhile, has anybody changed this before and could give me some more details on the procedure?
