I knocked the oil pressure sender off by accident the other week while changing my oil filter on my 94 3.4 (don't ask why I didn't just get it from underneathe). Anyway, I put the oil pressure sender back on minus the rubber o-ring that fall off, but my oil pressure only sits at about 1/4 according to the guage in the dash. Its the same at idle or at speed.
