how do you pull the damn thing!!! i have the 3 bolts on the front off, is there one one the back or what? any help? please!!! need to have it pulled in 2 hours.
a/c compressor
Re: a/c compressor
I feel your pain, Im trying to get mine out and it isnt moving either... do you have a haynes manual or chiltons?
ArcherMISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
Re: a/c compressor
those manuals are garbage when it comes to removing the compressor
there should be 2 bolts you need to take out in the back on a bracket, and another in the middle of the back of the compressor to take the ac lines off
edit* you will most likely need a swivel socket adapter, it makes it a ton easier
Re: a/c compressor
there are 3 up front, and another 2 in the rear?
I dont believe the book mentioned something like that
Re: a/c compressor
Originally posted by 96redbirdgt View Postdo i have to pull the idler also? if that is the case should i just pull the whole mounting bracket?
IIRC there is a bolt up front on the block and one on back for it
when i took the compressor out, i lifted it up from the top of the engine, it was much easier that way
i also left the bracket that holds the compressor on the block and just took the two bolts out of the compressor
Re: a/c compressor
there are three bolts in the front and a mounting bracket in the back.
you only have to take off 5 bolts and the belt to get it off the car.Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: a/c compressor
I was reading that after removing the belt, and disconnecting the electrical connector, remove the bolts on the front, jack up the car to get to the 2 bolts in the back. The back must be a bracket that both hoses connect to. Also I believe thats where 2 seals are also located.
Re: a/c compressor
Originally posted by tkoforpresident View Posti'm thinking of taking mine off of my 3.4
cuz i just bought a ac delte pulley.
and my ac doesn't even work.
would it be any different on a 3.4?
btw the 2 metal hoses in the back of the compressor are already disconnected, will this help with me taking it out?
Originally posted by KennyD View PostI was reading that after removing the belt, and disconnecting the electrical connector, remove the bolts on the front, jack up the car to get to the 2 bolts in the back. The back must be a bracket that both hoses connect to. Also I believe thats where 2 seals are also located.
i cant remember how many bolts are back there
and yes, that is where the two seals are, make sure when replacing them you put them on the right way and cover them with oil
Re: a/c compressor
Originally posted by cam98aro View Postyes it will help, but you shouldnt have disconnected them, unless you dont drive the car
both hoses form into one mount, which is held on by one bolt
