rough idle... - FirebirdV6.com/CamaroV6.com Message Board
rough idle...
  • rough idle...
    When the car is idling it's a little rough and the rpm needle is a little below 1 thousand rpms would seafoam clear that up? and give it a smoother idle? has anyone had this probelm and fixed it with seafoam?
    Thanks
    Re: rough idle...
    seafoam may do it
    did you just buy a camaro, or have you had one for a long time?
    all of these threads you are making are pretty common with the 3.8L engine
    sometimes my car shakes like it is over cammed
      Re: rough idle...
      I just got it about month and a half ago and these things just started happening wasn't sure if there was something I could do about it glad there normal and nothing serious lol but it being over cammed makes sence thanks
        Re: rough idle...
        how many miles on the car???? try changing the plugs and wires..o2 sensor(s).
        ....WHITE CAMARO CLUB....? =(
          Re: rough idle...
          It has about 140,000 yeah it has a lot of miles on it plugs and wires are new.
            Re: rough idle...
            There was a thread about this a while back, couldn't find it on search. Basically it was that if you replace the IAC adn TPS the problem is usually fixed. Someone feel free to correct if i'm wrong.
              Re: rough idle...
              ill look into it, i have gotten a freak TPS code a few times
                Re: rough idle...
                Coil packs might need replacing soon, also sometimes a MaF sensor will give you a rough idle you can try cleaning it or replacing it as well. just some ideas.
