What's this?
PCV Valve
Positive Crankcase Ventilation Valve
-Andrew1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
It maintains a vacuum in the crankcase to help seal the rings and reduce blow-by. Then the oil vapor and other blow by gasses are routed back into the engine to be consumed.1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
It's only a $7 part and takes about 2 minutes to change. Mine got stuck closed last year and after a night of hard driving oil was leaking out throught my throttle body, it made quite a mess. So I'd recommend changing it at about 50,000 miles.98 NOS\'d Camaro 3.8 A4<br />99 Hyundai Elantra 2.0 A4
<blockquote>quote:</font><hr>Originally posted by HPbyChevy:
Good example RS. (to bad it happened)
99, it's the easiest thing to replace (next to your old lady) under the hood. Besides, it's part of properly maintaining your ride.<hr></blockquote>
ok how and where do you get it? BTW, I have 54K on my car
Well you go to an autozone or advance auto parts or pepboys...whichever..tell them your car year and engine size and let them get the pcv valve for you..Its quite simple i changed mine about one week ago and it took about 2 min..It was recommended to me because i lost gas mileage and the pcv valve needs be changed about 35-40000 miles96 3.8l green camaro Y87 <br />(Sold January 28th, 2004) New whip (02 Civic SI)<br />\"Out with the bad..in with the good; out with the bad in with the good!\"<br /> <a href=\"http://members.cardomain.com/themeangreen6\" target=\"_blank\">http://members.cardomain.com/themeangreen6</a>
you want to replace it to keep the crankcase from building up positive pressure (from the blow-by gases). if its not working you can get leaks from the valve covers and intake manifold as the pressure finds another way out.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
