Car acting funny when A/C is on... - FirebirdV6.com/CamaroV6.com Message Board
  • Car acting funny when A/C is on...
    OK, my A/C currently works marginal at best due to a failing compressor. Still blows cool, good enough in fact until I rebuild the whole system when my stimulus money gets here...
    My car runs great, just did a full tune-up and everything, shifts perfectly, and loves it when I get on her.... that is, until I turn on my A/C system. When I do, its a totally different car...
    A definite vibration if felt coming from under the hood. Of course, this is due to my failing compressor. As long as I just BARELY cruise along, it seems ok. But if I get on it at all, it falls on its face. Feels like it has no power at all. Transmission also acts funny, the RPMs will go very high before the transmission will RELUCTANTLY shift into the next gear, if at all. Doesn't seem to want to down shift either. All the while, not a single code is set and no SES light...
    Turn the A/C off.. and voila, runs perfect again.
    Now my question is this...
    Is it possible that whenever the compressor is engaged, the vibrations are interpreted by the knock sensor as knock, therefore, pulling timing and causing all the weird problems?
    Also, what else changes computer-wise when the A/C system is on?
    Re: Car acting funny when A/C is on...
    It's more work on the engine when that ac clutch kicks in, especially if it's going bad.
    TEAM C6V6
      bingo
      ac compressors take a bunch of HP to run
      not to mention the added strain on your alternator running the blower motor, etc
        if the comp. is going. you might as well just change it to see what it does for you
        WAWA-A-HOLIC
          I save gas mileage by using my T-tops :) My girlfriend hates it. Wtf? She's annoying at best when it comes to cars anything.
          TEAM C6V6
            Thanks guys!
            Ohh, i will definetly be changing it very soon.
            But is it possible though, for the vibrations to be mistaken for knock? I mean, I know the compressor draws alot of HP to run, but enough to actually affect the shifting of my transmission? The engine is rotating and seems like it wants to go but is being held back, like timing is being drastically pulled...
              i highly highly highly doubt it
                It's your compressor, it'll make the car slower and you hear the rpms and think it should be shifting.. Somethin to that effect. My car is pretty different when I have the AC on and I try to really get on her.
                TEAM C6V6
                  werd, my car acts like it has a misfire, or the clutch is slipping with the ac on
                  it feels like it has the same amount of power as a 100hp FWD car, and when letting off of the clutch it feels like it has no torque, and the rpms drop and dont seem to want to pick up
                  and then sometimes after the clutch is let out, it will pause on acceleration for 1/2 second, then go again
                    Your car has issues. Are you talking about a m5 clutch or ac comp clutch?
                    TEAM C6V6
                      the drivetrain clutch
                      it only does it when the ac is on
                        It sounds like your is having a hell of a time turning the ac compressor, maybe its goin bad if it's acting up that much. Unless manuals do this off the lot eh?
                        TEAM C6V6
                          very well may be
                          the clutch on the compressor feels hard to turn
                          every once in a while it makes a grinding noise when the clutch is not engaged
                          i have to spray some wd 40 on it and it wont make the noise till the oil goes away, i did see some metal shavings around there today, so yeah i might have to put the clutch from my old compressor on there.. just not sure how it works with the seals and everything
                            Lol, I tape my gf's mouth shut and she's quiet till she gets it off. But that's only temporary and it's not a real fix to the problem that she never shuts up. But I suppose if it was really bothering either of us we'd fix it correctly eh?
                            TEAM C6V6
                              I save gas mileage by using my T-tops :) My girlfriend hates it. Wtf? .
                              hubby doesn't understand the freedom of the t tops, windows down and music blasting. IDIOT:slap:
                              WAWA-A-HOLIC
                              • 187shark
                                by 187shark
