i just got my car back from the body shop and i was driving home and noticed a horrible misfire. when i got home i popped the hood and saw two wires had a spark between them on the ignition coil. i forget which cylinders they are, but its the top right coil on a 3.4L.
my question is how bad is it to drive with this happening? i'm suppose to work tomorrow and its a 25 mile drive each way. should i call in and avoid driving my car any or could i go and wait til i get off work to fix it?
94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
Depends how bad the car feels to you. How old are your plug wires? Are they pushed down all the way? Is that ignition coil cracked?
it got progressively worse as i drove home. by the time i got home it was sputtering really bad. the cracking noise from the spark is really loud too. i pulled both of the plugs off and put them back on tight. one of the coils if black. i've decided that i won't risk going to work. plus sat is my last day at that job so i don't really care if i miss work.
Originally posted by Predator Bird: it got progressively worse as i drove home. by the time i got home it was sputtering really bad. the cracking noise from the spark is really loud too. i pulled both of the plugs off and put them back on tight. one of the coils if black. i've decided that i won't risk going to work. plus sat is my last day at that job so i don't really care if i miss work.
sounds like the coil pack has gone bad
yeah def dont go to work... at least not in that car. misfire=really bad
2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
I have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...
