My front right turn signal light bulb went out so I went to replace it and the entire socket was melted (charred all over, and a lot of the plastic turned to goo); not sure how it happened...but obviously I'm going to need to replace it. I picked up ACDelco Part LS54 from my local dealer. It's exactly what I needed but cost $60! Anybody know where else I can get this for a lesser price?
Should I just go to a junkyard and cut it out of a car? Is this a universal part, or Camaro's only?
Red 3.8L 99 Camaro<br /><a href=\"http://www.humorkingdom.com/kevin/carpics/\" target=\"_blank\">Click here for pictures</a><p>- SLP Whisper Lid<br />- Fast Toys Ram Air Kit<br />- K&N Filter<br />- ROH R/T 18x8 Black Ice Wheels<br />- Kumho Ecsta Supra 712 245/40/18 Tires<br />- 20% side tint, 35% rear, 20% strip up front<br />- Clear corner lenses and older Camaro tail light conversion<br />- Chrome Exhaust tips; Ravin Z55 Muffler<br />- 1600 (1000 RMS) Watt American Legacy 2 Amp<br />- 1000 (500 RMS) Watt Pyramid Hyper Pro Subs
Just used the search feature, and found most people had to get this from the dealer, which I did. I'd like to hit up a junk yard though and take this one back - is this a universal socket (in GMs) or should I have to pull it off a 4th gen Camaro or what?
i had the same problem with my clear corners and the bulb burning out. i just took out the whole lens and drilled a few small holes into the bottom plastic so that any water that got in would drain out. i replaced the bulb and haven't had the problem since
Yeah, mine is with the clear corner lenses as well? Is this happening because of the moisture accumulating in there, and causing problems? I guess I'll replace the socket and drill some holes as well.
