SERVICE ENGINE SOON LIGHT - FirebirdV6.com/CamaroV6.com Message Board
  • SERVICE ENGINE SOON LIGHT
    Hey guys my SES light came on during my drive to work . Called the dealer and can't get it in till next tuesday. My question is can I drive my car till then, it seems to be runnig ok so far?
    Randy
    97SILVERBID<br />Born to cruise
    If its not a flashing SES light you should be fine, and I would take it to autozone and have it scanned way before taking it to the dealer!
      Autozone = Free diagnosis
      Dealer = Probably $80 to just scan
        I'll try autozone after work , if it's a sensor will they have the parts I need?
        Thanks again for your help.
          More than likley they will. If you can stay away from the dealer, cost is way high. More times often than not like Nachius said "if you are not flashing it is okay to resume driving" Hit tha zone, find out the issue-things usually work okay from there. Keep us posted
          -235/4517 Chrome Mondera Solaris<br />-Hornet remote start-keyless entry<br />-Pioneer 8400/CD/MP3<br />-2 Audiobahn 10\'s in custom box<br />-Flowmaster exhaust-SLP CAI-*180<br /><br />Never underestimate the predictability of stupidity....Tony from \"Snatch\"
            Went to autozone and they did a check and I had a code for the cam sensor , cost me $40 and five minutes to put in. You guys saved me a good chunck of change. Super job leading me the right way
            THANKS AND HAVE A GREAT 3 DAY WEEKEND
              wait cam senors take at least 2 hours to get in
              BTW always check your gas gap i had a cracked one and it set off a SES light.
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                lol, he might have meant something else. something alittle easier to get to.
                2000 3.8 A4 Pewter Camaro
                  How does cam positon sensor sound,it's on the block just behind the pully,sorry for the confusion .
                    Originally posted by viper04af:
                    </font><blockquote>quote:</font><hr />Originally posted by 97SILVERBIRD:
                    wait cam senors take at least 2 hours to get in </font>[/QUOTE]If it takes you 2 hours to change the CMP Sensor, something's wrong:
                    1. Disconnect the negative battery cable.
                    2. Disconnect the electrical connector from camshaft position sensor.
                    3. Remove the camshaft position sensor retaining screw.
                    4. Remove the camshaft position sensor.
                    Edit: #5. http://home.cfl.rr.com/mkaprocki/Camaro/L36_Diagram.jpg
                    Matt
                    1998 Mystic Teal Camaro M5
                      98 Where are you pulling those diagrams from? That's the second one I've seen.
                        Sorry, I missed your post. It's from the GM Service Manual CDs. ;)
                        Matt
                        • Andy H
                          Transmission removal help!!
                          by Andy H
                        • 2.8 Bird
                          Abs inop
                          by 2.8 Bird
                        • fishin
                          by fishin
