ok so today i was driving to work and iv never had a problem with my window. when i got off work my window wouldnt go down. i turned the car off and on and ity went a lil bit. it works a lil and then stops. works a lil then stops. whats my problem? what needs to be replaced and how much will it cost?
window problem
Re: window problem
Originally posted by kylerobison View Postok so today i was driving to work and iv never had a problem with my window. when i got off work my window wouldnt go down. i turned the car off and on and ity went a lil bit. it works a lil and then stops. works a lil then stops. whats my problem? what needs to be replaced and how much will it cost?
Re: window problem
Originally posted by kylerobison View Postits not the regulator? whats the regulator dude? but it worked this morning and my passenger one works. anyway it could be the buttons?
Re: window problem
Originally posted by 95firebird3.4 View Postno the window regulator is what the motor goes onto and thats just to keep the window on track. it could be the switch but i dought it. take the switch out and clean it with rubbing alcohol and see if it fixes it
anyways, im still guessing it is the motor since i have never heard of a switch going bad on our cars
Re: window problem
Originally posted by cam98aro View Posthad the same exact problem with my dads car (not f body though) and it was the switch
Re: window problem
Originally posted by 95firebird3.4 View Postit did on my 95 i was so piss replace the motor then found out it was the switch
if you didnt press it down all of the way it worked fine, but if you used the switch it took about 30 min to get the window to go up
Re: window problem
just did mine this weekend. total nightmare but got it done. i paid 43 bucks for mine at advanced autoparts w/ lifetime warranty.
Follow me!
Or this
Re: window problem
Originally posted by vanbibber View Postjust did mine this weekend. total nightmare but got it done. i paid 43 bucks for mine at advanced autoparts w/ lifetime warranty.
TEAM C6V6
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...10 hours ago
