reviving fuel injectors - FirebirdV6.com/CamaroV6.com Message Board
  • reviving fuel injectors
    anyone know where i can find a how-to on how to refresh old fuel injectors? fwiw this is on my old car that hasnt been drivin in a while.
    I read you can soak them in wd-40 or something
    Re: reviving fuel injectors
    Have you considered that fuel additive stuff that says injector cleaner on it? Not sure how well they work though. Make sure you mix it into a full tank, or whatever the directions say.
      Soak the ends in seafoam, then take a Q tip and clean the openings. Check them with a OHM meter should be between 10-19 ohms, to make sure their still good.
        2 days ago
      • Doodler
        97 Camaro base with expensive sounding noises
        by Doodler
        Still trying to find oil leak
