Hey guys quick question, Is it okay to just run water in the car without any coolant at all?
Water
Re: Water
Originally posted by tkoforpresident View Postyeah, use distilled water.
but seriously, why not get a couple gallons of premixed?
Re: Water
Originally posted by zpwn06 View Postpremixed? if you're trying to save money, water is usually pretty cheap... get unmixed then put your own water in. Distilled water isn't really very cheap either. Anyway, I wouldn't run with less than 30% antifreeze because of the corrosion protection08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Water
premixed will cost about the same as buying bottles of regular and distilled water
Re: Water
Originally posted by cam98aro View Postspending $15 to fill the car up with coolant is better than spending the $1500 it will cost for a shop to replace the engine
Re: Water
Mixing coolant with water to increase the boiling point. Water will boil too quickly resulting in overheating and water alone will rust your rad and other parts very very quickly. Coolant has rust inhibitors to stop rust from forming and lubricants that help keep your thermostat opening and closing when it needs to prevent overheating/overcooling. Coolant raises the boiling point of water to effeciently keep the engine at normal operating temperature.
Dont risk it...Dexcool is 15 bucks for a pre mix.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
