Water - FirebirdV6.com/CamaroV6.com Message Board
Water
  • Water
    Hey guys quick question, Is it okay to just run water in the car without any coolant at all?
    Re: Water
    i wouldn't do it for very long.
    are u out of $ or something?
      Re: Water
      Not even just for the summer time?
        Re: Water
        If you're going to use just water, don't use tap water. It will cause scaling on the surfaces (making heat transfer worse), and will accelerate corrosion.
        '99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
        '97 RS - HPTuner, Bolt-ons
        '09 WRX - Aesthetic mods
          Re: Water
          yeah, use distilled water.
          but seriously, why not get a couple gallons of premixed?
            Re: Water
            are you just messing with us? cheap coolant is like 7 bucks... :slap:
            my other truck has a 50 cal mounted on it
              Re: Water
              hey with gas prices the way they are, i don't blame anyone for trying to cut corners, but the cooling system is not a good place to start.
                Re: Water
                premixed? if you're trying to save money, water is usually pretty cheap... get unmixed then put your own water in. Distilled water isn't really very cheap either. Anyway, I wouldn't run with less than 30% antifreeze because of the corrosion protection
                  Re: Water
                  Hey thanks everybody ima go grab some in a few minutes then....maybe my car will run a little cooler too
                    Re: Water
                    At least 30% for the protection.
                      Re: Water
                      spending $15 to fill the car up with coolant is better than spending the $1500 it will cost for a shop to replace the engine
                      premixed will cost about the same as buying bottles of regular and distilled water
                        Re: Water
                        unless you either have really ****ty tap water, its usually works fine. If you have hard water or something, its a no-no though. I would rather use distilled for the peace of mind, but if your trying to save money, you'll be fine.
                          Re: Water
                          Mixing coolant with water to increase the boiling point. Water will boil too quickly resulting in overheating and water alone will rust your rad and other parts very very quickly. Coolant has rust inhibitors to stop rust from forming and lubricants that help keep your thermostat opening and closing when it needs to prevent overheating/overcooling. Coolant raises the boiling point of water to effeciently keep the engine at normal operating temperature.
                          Dont risk it...Dexcool is 15 bucks for a pre mix.
                            Re: Water
                            The pressure cap on the radiator raises the boiling point of the water also.
                              Re: Water
                              So you guys are telling me that it's cool to run DexCool in a 94' Camaro? I thought that was for like 97' and up
