I was checking the coolant level yesterday and I noticed that it started leaking. I looked around and could see it pooling up around the water pump. The strange part is it only leaks when the radiator cap is off. As far as I can tell, it doesn't leak when the cap is closed. The car is a 94 3.4 M5. Anyone have any ideas? I'm confused.
Strange Leak
Re: Strange Leak
Here's what might be happening. You ever dipped a straw into your drink, put your thumb on the end, and took it out? The drink stays in the straw until you release your thumb. That concept may apply here as well. Does it leak when the engine is running? How big a leak we talking about also...'99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
'97 RS - HPTuner, Bolt-ons
'09 WRX - Aesthetic mods
Re: Strange Leak
Originally posted by Mr. Logger View PostHere's what might be happening. You ever dipped a straw into your drink, put your thumb on the end, and took it out? The drink stays in the straw until you release your thumb.
Re: Strange Leak
I checked around where the coolant was pooling up with the engine running, and it was leaking with the cap on. I just had the pump and gasket replaced a few months ago, but I don't know what else it could be. I wonder if the coolant could be sludging up again. I seem to have a problem with the coolant sludging up when I put real antifreeze in... I'll check tomorrow when I have more daylight. This is depressing though. :(
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
