Ok, I just noticed this yesterday. When the AC is off the car is fine, but when I turn it on, the compressor is noisy. It rattles pretty bad. I checked all the bolts and they are tight, and the clutch doesn't seem loose. The AC works good, nice and cold. Any ideas?
Rattling AC Compressor
happened to my Beretta back in 97. Making a bunch of rattling noises and was hard to id where it came from. But, turning on the AC seem to have some sort of effect on the noise. One day, while going up the hill the condenser locked up and the drive belt kept going. I smell some burning and some some puffs of smoke under the hood. Popped the hood and see the smoke coming from the AC area, then "SNAP" the belt broke.1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
same thing happened to me last week.... i turn the AC on and all i hear is rattling. so of course i thought it was the AC.... but when i popped the hood i found that a bolt had wiggled loose off of the alternator. so the little bit of tension the AC puts on the belts was just enough to make the alternator flap around. the bolt should be here today though so no more rattles [img]tongue.gif[/img]1999 Camaro Silver 5spd<br />Appearence Mods:<br />-Clear Corners -Tail Lights off a 93-96 Camaro -Painted Black Calipers w/ Silver Camaro Decal on front ones -Black Camaro Rear Fill Decal -Silver Camaro Front Fill Decal -Painted Silver Interior Pieces -RKSport Shift Knob<br />Performance Mods:<br />-Eibach springs -Whisper Lid -Removed MAF screen -Free Ram Air -Trans Am Dual Exhaust -3\" Cutout<br />Stereo System:<br />-Eclipse 8v Head Unit -Eclipse 87series 12\' Subs -Rockford Fosgate 800wt amp (subs) -MTX 225wt amp (highs)<p>AOL IM is jay eub, msn messenger is banks_2003@hotmail.com
its probably the compressor clutch. the compressor has an electric clutch built in to the pulley so the compressor can be engaged and disengaged on the fly. you should be able to replace the compressor clutch seperately. dont know if you need a pulley puller or it just bolts on. check your service manual.
You may want to get a new a/c clutch soon (which is prob what it is) so it doesn't freeze and end up leaving you stranded somewhere.2006 Tiburon
I checked everything and it's not anything loose like the alternator or AC mounts. The tensioner seems fine too. The noise is hard to pinpoint, seems like it could be anywhere on the AC compressor side of the engine, but it ONLY happens when the AC is on. I think I may replace the clutch and see if it helps. Otherwise, I have no clue. Thanks for the info frome everyone...1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
